Personal Experience On Replacement Chip
Personal Experience on Replacement Chip
Today's video is about Repairing Toshiba L650D. It’s Inventec manufacturer product.
Motherboard model is 6050A2333101-MB-A02 and the motherboard has discrete graphic.
The main graphic number is 216-0772000 .And it has AMD sampron CPU and AGP, the second graphic of the motherboard is integrated graphic chip and its code is 216-0752001. He didn't have this graphic chip
So he soldered different graphic chip code, its code is: 215-0752007. After soldering and connecting this CPU didn't work, its Amper remains 1.23 Amps the Amper is normal so, it should work but the graphic is not here! He changes the AMD sampron to AMD Turion. And its ROM is 2GB. Thereafter Amper is in its stable mode, so in this way you can use replace chips with different chip code.
  • Toshiba_L650D_Chip_replacement_-_215-0752007_EN.zip
