File Request HP Compaq 6730b
xit01234
Bronze
MotherBoard Model
6050A2219901-MB-A03
Hello,
Wifi is whitelist on bios F17 and unable to upgrade. Attched bios F17.
I referenced searched on the web the motherboard model from the SKU Nmber KR971UT#ABA from bios to 486248-001 to 6050A2219901-MB-A03 please verify.
Thank you.
  • sp51317.zip
Vahab Hemmati
Support Team
Hello,
Thank you.
  • 6730b fix.bin
xit01234
Bronze
Hello,
The original file creates a folder with the HPQFlash.exe program and only flashes the original F17 bios. I tried renaming the your 6730b fix.bin to exe file but doesn't work. How to use this new bin file to flash the laptop?
Thank you.
xit01234
Bronze
Hello,
I was able to find the DOS Flash utility by downloading F14 bios from HP 6730b site. I replaced the bin and renamed. Copied the files to a FreeDos USB and flashed the 6730b. Powered Down and replaced the WiFi Card. Rebooted and received this message...
104-Unsupported wireless network device detected.
System Halted. Remove device and restart.
The bin file did not fix the problem. Thanks.
xit01234
Bronze
Hello,
I flashed the update.bin no the bios reads as F20. I default bios to factory and installed new WiFi card. I get the same message...
The update.bin did not work. Thank you.
xit01234
Bronze
Hello,
I flashed the update.bin now the bios reads as F20. I default bios to factory and installed new WiFi card. I get the same message...
xit01234
Bronze
Hello,
I'm unable to go back to F17, now that bios is F20. I have downloaded F20 bios and extracted the ROM.CAB to a zip file attached. Possible to try again as I do want to keep this HP 6730b Laptop. Thank you for you time and services.
  • hp6730b_rom_cab_f20.zip
xit01234
Bronze
Hello,
I tried the new bin file , same error message. Whitelist blocking new mini pci-e wifi card.
Thank you for your time and efforts.
Merry Christmas!
There are currently 1 members watching this topic
xit01234
Users who has read this topic
